Hiss from wiper solenoid under dash
I have a hiss coming from the wiper solenoid under my dash. I hear it when I shut the car off. I'm guess vacuum from the system is leaking out of there.
Everything in the vac system works nice and quick with the engine running.
Any ideas? I tried plugging the nozzle that's making the hiss & then my wiper door does not work.
Re: Hiss from wiper solenoid under dash (DaddyO)
The seat has some dirt on it. Go here on how to fix the problem.
http://www.71corvette.com/wiper.html
Does your wiper door open when you shut down the car or does it open then close when you start her up? These are tell tale signs of a dirty solenoid. Mine had these symptoms and the hiss and after I performed this procedure all that went away. Good luck it’s a pain to get out and back in but it can be done. I suggest removing the driver’s seat to make it easier to get to the solenoid.
