brake line replacement with body on car??
I remember there was something about this from a post long ago.
Can you replace all the brake lines without lifting the body?
Re: brake line replacement with body on car?? (70 LS1)
:smash:
Yup... I did it with car on jackstands about 16" off ground. I started with pre-bent SS lines and left the caps on cuz there is a lot of poking and proding involved It just takes patience and a little distorting here and there but it can be done in a few hours. The hardest parts were the front passenger wheel and getting from the porportioning valve to the rear driver side block.
I don't remember anything special I did...I just flailed away and it all worked out
