Need 327 300hp Stock Cam Specs
Cruising
Anyone know the lift and duration of a stock 327 300hp camshaft? It is on my '68 Vert. Any help would be appreciated.
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: Need 327 300hp Stock Cam Specs (benjtay)
Crane Cams is now providing the 327/300 hp cam in their "Blueprint Series" cams. They are supposed to be exact duplicates of the GM cam, but ground to exact measurements (unlike factory cams.)
Go to Crane's website and maybe you can find the exact specs on it. Jeg's has it listed as 195/202 degrees, .390"/.410". RPM Range 1000-3200.
