73 manual to power brake conversion
Cruising
I hadthe ZIP power brake conversion installed by a friend. Right afterwards, I installed all new calipers and rubber brake hoses. I had the system power bled after bleeding it manually for a day.
My problem is the pedal seems low or a little soft. It still stops well and can lock the tires. Has anyone done this and cured the low pedal? I was not present to see if there was a pushrod adjustment, my friend said no.
Thanks,
Jon
Thanks,
Jon
