Adding wire looms...
If I loosen the stud on the valve cover but do not remove the valve cover, I won't need to mess with a new gasket, will I?
-Steve
-Steve
Re: Adding wire looms... (Pacin'California)
I have loosened the bolts several times so I can take the wire looms off when I have been working on the headers or changing plugs and have not had to mess around with the gaskets. I always keep a spae set of gaskets around just in case though. :thumbs:
