Is the Rocker panels for a 68,69......Same as the 70-78 model year?
Re: Is the Rocker panels for a 68,69......Same as the 70-78 model year? (Alwyn678)
68-69 are two piece fiberglas panels. 70 and up are one piece aluminum. The 70 will go directly on 69's bu I'm not sure if you can use the fiberglas one on 70's cars .
[Modified by bluevetteman, 5:01 PM 10/1/2003]
Re: Is the Rocker panels for a 68,69......Same as the 70-78 model year? (bluevetteman)
Cool my buddie wants to put aluminum from a newer model on his 69 so He should be golden :cheers: :cheers:
Guest
Posts: n/a
