5 speed transmission ID- Part II
Old 10-01-2003, 09:26 AM
Shrike
Shrike's Avatar
Default 5 speed transmission ID- Part II
OK, looked at the trans last night, definitely a T5. It does say Borg Warner on the left side, but no other marking I could see except for "basic- l" up high on the left. Should there be some sort of ID number on it somewhere? If so where?
Thanks in Advance,
Scott
Fevre- here is a pic of the shifter, working on the other pics.
Old 10-01-2003, 09:38 AM
Fevre
Fevre's Avatar
Default Re: 5 speed transmission ID- Part II (Shrike)
Thanks for the pic, that doesn't look to far outa whack. Here is one way to tell:
the plug that is circled, if it is a bolt and it says ROCKFORD on it, then its a nonWCT5, if its a TORX fastener then its a WCT5. to find out more about the differences between NWCT5`s and WCT5`s check out this sight here, http://www.5speeds.com
Sorry pic did not attach, there is a bolt on the driver side of the trans, it is the top bolt in the middle of the case.
Check this link for the pic:
http://www.thirdgen.org/techbb2/atta...postid=1111927
[Modified by Fevre, 8:44 AM 10/1/2003]
Old 10-01-2003, 10:25 AM
Shrike
Shrike's Avatar
Default Re: 5 speed transmission ID- Part II (Fevre)
Fevre- thanks for the info! There are a few more pics of the shifter located here: http://libraries.uta.edu/sholmes/tranny/index.htm
Old 10-01-2003, 10:30 AM
Twin_Turbo
Twin_Turbo's Avatar
Try to take a peek in the bellhousing. Non WCs have a steel plug over the counter shaft baering race, the WC's have a sealed timken tapered roller bearing there where you can see timken engraving on it.
[Modified by Twin_Turbo, 9:32 AM 10/1/2003]
Old 10-01-2003, 10:38 AM
Fevre
Fevre's Avatar
:thumbs:
To 5 speed transmission ID- Part II
Quick Reply: 5 speed transmission ID- Part II
