What are the major differences between a '68-'69 L88 & L89??
Have heard several versions of the differences,
does anyone know for sure??
Were these only big block options??
Re: What are the major differences between a '68-'69 L88 & L89?? (PB82CE)
I cannot tell you the specific differences, but the L88 was the all out racing engine. The L89 was the tri-power L71 engine with alumn heads.
The big blocks were:
L36 427/390hp
L68 427/400hp (tri-power)
L71 427/435hp (tri-power)
L71 with the L89 Option
L88 427/430hp (rating downgraded to keep people from buying it for street use)
tom...
[Modified by Tom73, 7:15 AM 10/1/2003]
L36 427/390hp
tom...
68-69 L-89 Tri power, closed chamber aluminum heads, 11.1 C.R., .500-.520 lift cam, depending what specs you look at, 3/8" dimple rods, single valve spring w/damper, 3/8" pushrod
68 L-88 high rise intake, Holley 4bbl, closed chamber al. heads, 12.5 to 1 C.R. Wilder cam, cold chamber hood, .560 lift cam, longer duration, 7/16" rods, dual valve springs w/damper, 7/16" pushrod
69 L-88 same as 68 L-88 but open chamber aluminum heads, open chamber pistons
[Modified by GDaina, 8:53 AM 10/1/2003]
