73 dash lights
73 dash lights
The lights on the dash only come on when turned all the way up and then the blinkers light up along with the brights. Is there a ground disconnected? if so from where?
Re: 73 dash lights (brookman)
There is aground wire that attaches to the back of the speedo. You may have a broken headlamp switch The part that adjust the brightness was broken on mine.
Re: 73 dash lights (redwingvette)
Do you - or does anyone have a picture of the back of the dash? (particularly where the ground connects) I would like to try and connect it without dissassembly.
Thanks
Thanks
Sorry but I don't. I don't think you can reach it without taking it a part. Things are very tite back there. If the gruop of wires are not in the right position when you put it back together the dash won't fit. There is a couple of soft metal clamps that hold the bundle of wires where they belong. If they aren't held they hit the metal frame and hold the speedo/tach out. I tried to change some of the light bulbs and couldn't do it without taking it apart.
