Edelbrock Performer RPM Air Gap or 1970 LT1 intake will it clear hood
Old 09-30-2003, 02:11 PM
Khaalathas
Khaalathas's Avatar
Default Edelbrock Performer RPM Air Gap or 1970 LT1 intake will it clear hood
I have a edelbrock performer rpm air gap and 1970 lt1 intake pretty sure the lt1 will clear will the air gap clear stock hood on a 1980 corvette using 14" air cleaner open element thanks in advance, Travis
:reddevil :reddevil :reddevil
Old 09-30-2003, 02:44 PM
Robert N
Robert N's Avatar
Default Re: Edelbrock Performer RPM Air Gap or 1970 LT1 intake will it clear hood (Khaalathas)
The LT-1 intake will require a drop base. Mine has little room under the BB hood, but I have heard they will fit with the right drop base and lid.
Old 09-30-2003, 03:16 PM
Robs73
Navigator
Robs73's Avatar
Ive got a 73 with a RPM Air Gap and a stock mid rise hood from 73 and there is about 3/4 inch clearance jsut watch for engine torque movement when you hit the gas but I solved that with a set of Mounts from Energy Suspension. :steering:
Old 09-30-2003, 03:23 PM
79Corvette02
79Corvette02's Avatar
As far as I know, the Performer RPM Air Gap will NOT clear a stock hood on a C3, it didn't for me, I had to use a drop base, and I would assume you will have to as well. :cheers:
Old 09-30-2003, 03:59 PM
Khaalathas
Khaalathas's Avatar
Default Re: Edelbrock Performer RPM Air Gap or 1970 LT1 intake will it clear hood (79Corvette02)
so does teh air gap fit with the stock hood and drop base then or did you require a taller hood also is the 79 hood same ht as an 80 im new to corvette ownership so not totally familiar yet i do have a edelbrock drop base on teh air cleaner i am assuming that is what you are referring to. thx again
Old 09-30-2003, 04:34 PM
79Corvette02
The RPM will fit a stock hood just so long as you use a drop base air cleaner, and yep, the 80 hood is the same as a 79. :cheers:
To Edelbrock Performer RPM Air Gap or 1970 LT1 intake will it clear hood
Quick Reply: Edelbrock Performer RPM Air Gap or 1970 LT1 intake will it clear hood
