Need Q-Jet jets/rods: any Forum supporting vendors sell any?
I *think* that I'm looking for 74/47 jets/rods combo for my lightly modded '75 coupe (trying to confirm with Lars!). Does anyone know if any Forum supporting vendors carry these parts?
TIA
TIA
Re: Need Q-Jet jets/rods: any Forum supporting vendors sell any? (Frank75)
Lars has them! Check my sig. He provided the jets/metering rods in exchange for my stock components.
[Modified by TedH, 12:36 PM 9/29/2003]
If not Lars, check out Carbs Unlimited at: http://www.carbs.net/quadrajet.asp
[Modified by TedH, 12:38 PM 9/29/2003]
Re: Need Q-Jet jets/rods: any Forum supporting vendors sell any? (TedH)
Ted, that's great to know! Carbs Unlimited is my backup choice but I'm hoping to hear from Lars soon. Lars - are you there?? :D
If you want the GM (AC Delco) parts you can order them by part number from forum supporting vendor GMpartsdirect.com . You can also order them from your local Chevy dealer. Typically you pay more at the dealer but no shipping charges. I don't have the part numbers in front of me, but I can dig them out if you need them. If you are getting advice from lars (a good idea! :) ) he will have the part #s for you.
Edelbrock makes equivalent parts with their own numbers; They are available from speedshops and vendors that carry Edelbrock, like summitracing or jegs. MJ
I have purchased rods and jets from GMpartsdirect.com, from my local chevy dealer parts department, Edelbrock parts from summit, and the carb parts vendor you mentioned.
[Modified by MNJack, 1:34 PM 9/29/2003]
Received 4,924 Likes
Frank -
You can order them from any GM dealer. I have the part numbers in my Q-Jet Tuning paper.
The 74/47 combo might be just a tad on the lean side of you have some mods. Bumping up 2 sizes from the stock #72 in a '75 Vette will richen you up a tad at WOT, but the #47 rods will keep your cruise mixture almost unchanged from stock. Try runing a set of 46 rods with those 74 jets - this will produce a little bit of an improvement at cruise and idle with a modified engine.
Re: Need Q-Jet jets/rods: any Forum supporting vendors sell any? (lars)
Okay - thanks Lars. The car has headers and true duals (2 1/4") at this point. I didn't see the part nos. in the tuning paper but maybe I was looking at the wrong thing. I saw the 74/47 combo in past posts with cars with similar mods.
So that means I can keep the stock rods, right? (stock combo is 72/46). That simplifies things a lot. thanks again
Frank
[Modified by Frank75, 3:46 PM 9/29/2003]
Frank
I couldn't find them either.... try this:
http://www.netspace.net.au/~peterpam/main.htm
And for the Edelbrock parts, try the edelbrock website:
http://www.edelbrock.com/automotive/index.html
here is the exact page:
http://www.edelbrock.com/automotive/...et_access.html
MJ
[Modified by MNJack, 1:12 AM 9/30/2003]
[Modified by MNJack, 1:13 AM 9/30/2003]
MJ
Re: Need Q-Jet jets/rods: any Forum supporting vendors sell any? (MNJack)
Thanks for the links. The 46 rods are stock for me, so all I need is jets.
Frank
Frank
