Removing differential in a 1980
Have a current post regarding replacing a seal around a yoke. Was told
the differential would have to be removed. Can someone post the
an outline of the steps needed to remove it.
Re: Removing differential in a 1980 (mark79,80)
Remove spare tire carrier & mufflers/exhaust, heat shield under camber bracket etc. etc.
Remove the spring
Remove camber bracket & camber rods (note position of cam bolts)
Remove 1/2 shafts
Remove driveshaft
Place a jack under the diff
Undo pinoon bolt and both batwing bolts
Slide the diff from under the car.
Remove the spring
Remove 1/2 shafts
Remove driveshaft
