Cutting Gymkhana-type front coils
I'm replacing alot of my suspension (poly all around, ball joints, shocks, etc.) I was going to get VBP's 550lb springs and cut them to get the desired ride height, but I found used Gymkhana springs for only $40. They are supposedly off a 10,000 mile car, would they be much different than getting VBPs springs and cutting those? Eventually (probably in a couple years) I plan to be replacing them with a composite front spring.
Thanks for the help, I'm excited to see how this car can really handle!
-Chris
[Modified by RUXperienced, 9:00 PM 9/27/2003]
-Chris
Re: Cutting Gymkhana-type front coils (RUXperienced)
The Gymkhana springs shoudl set you pretty low. Hmmm...do you know if they're off a big block car or small block?
How many coils do they have and what's their free length as compared to a stock coil?
There shouldn't be any reason you can't cut them if you think the car sits too high with them. Mine is sitting pretty much at the low end of the Gymkhana spec and it's just about perfect for me.
It's alot of work but I'd definately put them in and see how they sit before I cut them. Miles mean something but if the car sat on those springs for several years they are sagging from that. If I remember right for every coil you cut it'll drop 1 inch. :D
Re: Cutting Gymkhana-type front coils (GDaina)
You want to cut the coils? What on earth for? You like to scrape the oil pan as you're tooling down the road?
It's off a '78 Pacecar, so it must be SBC. They look to have 8 turns, whereas VBPs have 7, which may be a trivial difference. Unsure of their length.
by cutting the coil, you are not going to improve handling. If imroved handling you seek, poly bushings and composite front and rear springs will achieve what you seek. The FE7 coils will lower the car.
I'm looking for a lowered center of gravity for handling purposes, and a lower stance in the front for aesthetic reasons. I am actually buying new poly bushings all around, but the composite front spring is wayyy out of my budget for now (college student, hehe) Thanks for the pointers!
-Chris
-Chris
Cutting the coil will give him more spring rate on the nose. Dial in more understeer and what not. How is that NOT going to affect the handling?
I think, though, that the 550s sit quite low as it stands. More than low enough. I have to raise mine to clear headers. Maybe you should consider something with beefier coils- sits as low as the 550s but offers a higher springrate.
-Steve
-Steve
Is there any way other than RPO codes to know if you have Gymkhana suspension? I have read somewhere that the RPO tag is underneath the gas filler but I have never gone to the trouble to look. It would be nice to know if my 82 has Gymkhana.
Next question... How is Gymkhana different?
Re: Cutting Gymkhana-type front coils (Pacin'California)
Spring rate will change since the rate is dependant on # of active coils. The spring rate is a srping constant and it doesn't change when the spring is compressed, the thing that does change is the load. All springs sag over time, they loose spring load.
The spring rate is the amount of weight needed to compress the spring 1"
The spring load is the amount of weight needed to comprress the spring to a certain height. This is related to spring load of course. If the spring rate = X then the load to compress the spring 3" is 3X.
This is because the spring has less ehgith than before, imagine a 5 coil spring where you cut away one coil. Before the spring would compress and all 5 coils woul take 1/5th of the compression, now with 1 coil cut off 4 coils have to take up the same compression. So, the spring rate is defined for 1" compression, then the rate will go up from 1/5h to 1/4th.
This will most certainly have an effect on handling.
The lower Cg will have an effect on handling too, lower CG means less weight transfer and therefore less body roll (body roll is caused by weight transfer, not the other way around)
Re: Cutting Gymkhana-type front coils (Twin_Turbo)
With either VBP or these springs, I did plan to install before I decide whether I need to cut anything. I'm mostly curious how these coils compare to VBP's, they seem to have about the same number of coils, and same spring rate, but I thought they might sit higher because they weren't designed for a lowered ride height from the factory... or were they? I guess there's no reason they would react differently to cutting than VBPs would, assuming the need arises.
Thanks everyone,
Chris
Thanks everyone,
Chris
I have/had the Gymkana suspension and my front end sits in the air like a 4X4 truck. I am in the process of installing tubular control arms and composite adjustable spring. I'll sell you my springs if you are interested.
Monty Carlo springs have the same dimensions as our vets but are longer to start and allow cutting and come in higher rates then 550.
550's are pretty low to begin with and some require spacers to add a little height.
Why does everyone consider to make a car handle you have to run such high spring rates? It is just a bandaid to cover other probelms.
Re: Cutting Gymkhana-type front coils (norvalwilhelm)
What else can you do in the front, (proper sway bar of course) other than springs? I don't really have the ability to do the heavy modifications you and TwinTurbo are getting into... although I would if I could. I lack a garage, serious tools, and welding/fabrication skills. And of course, the almighty dollar.
Re: Cutting Gymkhana-type front coils (PigPen)
I just put in the 550 lbs/in springs from VBP and it dropped it just perfectly without mod's. About 1 to 1 1/2 " lower than stock.
As a side note, if you go to any SCCA or NCCC road races and ask if any of the drivers cut the coils for improved handling, I would be astounded if you hear one yes.
Was your stock spring a Gymkhana spring or a standard spring?
My 82s OEM FE7 springs up front sit at 28 3/8 height with 255/60R15s.
Brent...
Brent...
