Rear spring removal question.
Do I have to drop my exhaust to remove rear spring?
Can't the spring just be pull out the side after removing all bolts?
:confused:
TIA
:seeya
:confused:
TIA
:seeya
Re: Rear spring removal question. (Ed T)
Thanks Ed, but I just jacked the car up and found that my exhaust has to be dropped in order to get to two of the spring mounting bolts. :cry
I think I will take it to the shop to have them do the R/R of the rear spring.
I don't want to have to F with the exhaust situation, alot of the nuts and bolts are pretty rusted. I'm sure the neighborhood does not want to here alot of swearing on such a beautiful day.
:seeya
:seeya
Re: Rear spring removal question. (DMONSVETTE)
You can't get at em from the side with an open end wrench?
That's what I had to do. Then I found out I could move the exhaust right around the differential crossmember by loosening it up a little. Go figure!
-Steve
-Steve
Re: Rear spring removal question. (Pacin'California)
-Steve
-Steve
May just loosen exhaust at rear and move it over.
:yesnod:
Just finished replacing mine. It will slide out no problem with exhaust still intacted. Word of advise though .......Do not over torque the bolts when installed the new spring as the diff cover WILL crack. Trust me it happened. :thumbs:
Re: Rear spring removal question. (Ice_Fire)
I need to replace a broken rear spring... and also replace leaking axle seals while I'm in there.. What's the best way to go about this?
Ed T and Pacin' California, you guys were right. I loosened the bolts holding the exhaust in the rear, had enough room to get to rear spring mounting bolts. Also, after removing the heat shield I was able to get the open end wrench on the bolts. Luckily only one of the bolts was a b*tch to get off, even after soaking over night. The other three bolts came of fairly easily.
Only took me 2 1/2 hours to jack car up and remove spring.
I'm going to eat lunch while the paint on the rear spring mounting plate is drying and then back to the installation portion. Thanks guys for your suggestions, they really helped and they saved me money!
:cheers: :thumbs: :seeya
:cheers:
-Pedro
Spring is in! Thanks for your guys assistance. I can't believe I did all the actual work all by myself with no power tools. The back of the car is not sagging anymore and there is only about 2 inches in between tire and fender
using the 8 inch bolts. The body is pretty much level front to back.
Without the CF assistance I probably would have sent the work out.
By doing it myself I saved money, to buy other mods. I love it!
Just so you know, I have been running without that heat shield since April, put many miles on the car (hard and not so hard) and no problems yet.
-Steve
-Steve
