offset trailing arms
How did you put the shims on the inside of the arm? do they go on the inside of the trailing arm, kinda looks like it will rub the arm when moving. It kinda suk that the bushing are 1/4 inch shorter then factory. so I will have to use so of my old shims too. I am just trying to get it in the ballpark so I can get it aligned monday when I take it to work.
Thanks Larry :cheers:
