SPAL FANS........SINGLE OR DUAL, WHAT DOES SPAL HAVE OVER FLEXLITE AND OTHERS?
I have noticed quite a few of you have Spal electric fans. What advantages do they have over flex -lite or some of the others? I'm interseted in dual fans What size fans do I need? Do I purchase the push or pull type? What amperage should my altenator be should I choose to purchase electric fans Spal or otherwise? What advantages do dual fans have over single fans? (previous owner had a 3-row radiator and a single electric fan and the car did not overheat)
Re: SPAL FANS........SINGLE OR DUAL, WHAT DOES SPAL HAVE OVER FLEXLITE AND OTHERS? (Oldguard 7)
BTW The flex-a-lites are half the cost of the SPAL's.
[Modified by Fevre, 3:57 PM 9/26/2003]
Dual Spals are top of the line and include braggin rights at no extra charge.
A stock SBC with a decent radiator can probably do well with a single Spal or dual flexalite or single fan from a number of other manufacturers.
I got the dual Spals since I figured the overcapacity and high quality were cheap insurance against overheating int Texas in August.
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: SPAL FANS........SINGLE OR DUAL, WHAT DOES SPAL HAVE OVER FLEXLITE AND OTHERS? (flynhi)
Can you explain where you instal it?
You need to remove the original fan I guess?
Re: SPAL FANS........SINGLE OR DUAL, WHAT DOES SPAL HAVE OVER FLEXLITE AND OTHERS? (Smokehouse69)
:iagree:
:iagree:
Can't say enough about the dual Spal's. First time I put them in, with a new recored rad, the outside temp was hovering between 90-92, I let the 68 idle, 40 minutes in the driveway, the temp never reached 200. Needle was below the 200 mark.
Re: SPAL FANS........SINGLE OR DUAL, WHAT DOES SPAL HAVE OVER FLEXLITE AND OTHERS? (GDaina)
Flex O Lite has a new fan assembly out that pulls over 5000 cfm, with sensors and relays build right in and has the right size for the vette radiators. Sells for about $350=$400 from the parts houses. Sounds like a super solution for a reasonable cost. PROBLEM IS - according to flex-o-lite tech support the frame of the fan assembly does not clear upper A-arms on the vettes. They are redesigning and will have a new model in the spring that will clear the A-arms.
DeWitt's dual Spals will fit but cost may be a factor.
Re: SPAL FANS........SINGLE OR DUAL, WHAT DOES SPAL HAVE OVER FLEXLITE AND OTHERS? (bigvette1)
Be careful when comparing CFM ratings. I think it's true that Spal is the only fan manufacturer who rates fans under load/installed. Others rate their fans in free air.
Obviously free air numbers will look better.
CI 5-6-7-8-9 Veteran
Cruise-In 7 Car Show Winner
Re: SPAL FANS........SINGLE OR DUAL, WHAT DOES SPAL HAVE OVER FLEXLITE AND OTHERS? (Fevre)
Whats the best place, read cheapest, to buy the SPAL's at?
Frank
Frank
Re: SPAL FANS........SINGLE OR DUAL, WHAT DOES SPAL HAVE OVER FLEXLITE AND OTHERS? (garandfan)
Frank
Frank
