has anybody found a good set of 'shorty' AIR tube headers?
CFOT Attention Whore
the title pretty much sums it up. looking for a set of shorty headers, CARB exemption would be cool too, but they have to have the AIR tube provisions. also, a ceramic coating option would be very nice.
BTW, just in case your wondering, i simply don't have the ground clearance to switch to full lengthe headers.
Re: has anybody found a good set of 'shorty' AIR tube headers? (clutchdust)
I'm fairly sure that Sanderson has an air tube option on their tubular and cast headers. No EO number though. - I dont know of any shorties with air and EO numbers.
By good I am assuming you either have stock vette shorty headers and/or you do not think they are good. Not sure what year the vette starting the tubular manifolds but I would imagine they would/could be fitted to your set up.
:confused: You may want to drop that question on the C4 bunch. I think they use a fairly short header with A.I.R. fittings. :yesnod:
Consider best- get Dynomax Cerma coat, add air tubes if necessary, do a slight angle up where the ex. connects to headers in largest part of reducer.
That should do it, if not rec. modify the headers for slight upturn.
Location: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
Re: has anybody found a good set of 'shorty' AIR tube headers? (Ganey)
Gary I have a set of Sanderson shorties and they look great. I talked to their Rep. and he told me he would add the AIR tubes if you needed them for a small fee, then have them coated. They are really built good, the flange is one of the best I have seen and claim to require no gaskets. Jim
Re: has anybody found a good set of 'shorty' AIR tube headers? (PROSOUTH)
hi, jim! long time, no talk. did you get my e-mail? ;)
thanks guys. i will probably check into the sandersons. i've already done enough fabrication and i know i'll be doing more in the future so if i can have someone else do it, it'd be worth the extra money.
:cheers:
:cheers:
Cruise-In VI Veteran
Cruise-In VII Veteran
I have a set of "shorty" headers that came from an C-4 (I think) Originally they had a set of heat shields bolted over them and air tubes coming out the top. They are very much like a set of Rams Horn exhaust manifolds made out of stainless steel pipe. There are 4 seperate tubes about 1-5/8" in diameter that go down to a common 3 bolt collector flange.
I cut off the air tubes, and welded the holes shut, then cleaned and polished them up by wire wheel and sand blasting. After they were cleaned and smoothed I wiped them down lacquer thinner, and sprayed them with Techline Coating's Ceramicoat. Popped them into the oven for an hour at 500 degrees. At the end of the hour, I took them out let them cool and buffed them with 0000 steel wool. Instant Jet Hot like ceramic coating.
They are currently on an 82 Chevy truck that a buddy of mine is building for his son.
They look good but I don't think I'd use them on my 'vette. Dynomax headers are too good a value and would certainly out perform the shorties.
Another possibility is to buy a set of Dynomax headers and install your own air tubes.
