Proper Plug Gap with MSD Ignition
Does anyone know the proper plug gap when you run and MSD Ignition. There literature says to add .005 to .010. Does anyone have a more exact recommendation
Re: Proper Plug Gap with MSD Ignition (My69)
I read some webpage on MSD's site that said for naturally aspirated engines running up to 10:1 CR you should gap at 0.050 to 0.060.
In the instructions they say to gap your plugs at between .050 and 0.60, I have mine set at .050 and seems to work well. With my old GM system I used the old standard of .035 but I guess with the extra juice available from MSD you might just as well light the camp fire with a bigger flame!
Cruise-In III Veteran
Re: Proper Plug Gap with MSD Ignition (467-Ratman)
with an 8.5 compression ratio, MSD 6A, MSD Wires, and a Pertronix, and Rapid Fire plugs, I found 045 to run best.
:nono: I can’t find his book right now but I recall old Smokey said .050” for a high voltage box and nothing to gain beyond that. Also keep all wires ½” apart minimum with that high voltage ignition. The #5 & #7 wires need separation the most (18436572) and should only cross at 90* if possible to prevent induced misfires. He talks how surprised he was to find how many pistons were destroyed by misfire when something else was blamed for it. :conehead
Re: Proper Plug Gap with MSD Ignition (AlwaysWave)
Re: Proper Plug Gap with MSD Ignition (gdh)
my question is this: what difference would I feel by going to a 50 or 60 gap, would it be at the lower rpm range ie. 3500 and under. This is something I just never considered when I bought the MSD from a fellow forum member.
Too much gap will shorten plug wire life. No need to run super big gaps unless go have a lean/low compression motor. I set mine at .040".
thank-you for the reply, will get on this next week as well as rejet my 750 Edel Perf. carb from the factory settings.
