Replacement power window issue
Location: Inside every color vette there is a blue one trying to come out!
Has anyone ever had the power window motor short out because it is bumping up against something else? My window would not go back up...took a test bulp and the wiring is good from the switch to the connector...took test wire connected to postive batt terminal and got spark from both terminals on motor, indicating it was grouded out somewhere...began to take off regulator bolts and it started working. Anybody else have issues such as this?
Re: Replacement power window issue (Skruball73)
If the windings inside burn the varnish off or it dries from age or come looses and scrape a bare spot to the case, yes it will happen.
Re: Replacement power window issue (bigvette1)
