Clutch Neutral safety Switch.
Old 09-24-2003, 10:51 PM
Budman68
Budman68's Avatar
Cruise-In VII Veteran
St. Jude Donor '07
Default Clutch Neutral safety Switch.
Where do I get one for a 78?
Old 09-25-2003, 08:25 AM
Jim Shea
Support Corvetteforum!
Jim Shea's Avatar
Default Re: Clutch Neutral safety Switch. (Budman78)
The switch that is listed in my 1975 AIM book is no longer available through GM dealers.
I found a switch in my Zip Products catalogue (1-800-962-9632):
ES-311 69-81 Neutral Safety Switch, Clutch --- Call
(Usually not a good sign to have to call)
The Last Detail catalogue (1-888-527-8338):
675622 69-82 Neutral Safety - (M/T) *NOS $60
There are probably other suppliers that might stock them.
You might also try some salvage yards: http://www.gruhala.com/
http://www.corvettejunkyards.com/
http://car-part.com/
Hope this helps,
Jim
Old 09-25-2003, 08:31 AM
flynhi
flynhi's Avatar
Got mine from Gruhala.
Be advised that it is EXTREMELY hard to install with pedals and steering column in place. When I got my 71 vert, the CNSS had been removed and the circuit jumped. I found out why......
Old 09-25-2003, 09:29 AM
Budman68
Budman68's Avatar
St. Jude Donor '07
Default Re: Clutch Neutral safety Switch. (Ed T)
Ed, I sent you an email.
Thanks guys for the help. :cheers:
Old 09-25-2003, 10:23 AM
Budman68
Budman68's Avatar
St. Jude Donor '07
Thanks, Look great. The hand can't be yours, the finger nails are to clean. :jester
To Clutch Neutral safety Switch.
Quick Reply: Clutch Neutral safety Switch.
