If you had to remove the heads from your LT4......
The verdict is in. my ce has a blown head gasket after 90k miles. Hmmmm. What now? Provided the head is good (unsure of the likely hood of damage to the head?), a little work to it, or perhaps a new aftermarket head. Any suggestions??
Re: If you had to remove the heads from your LT4...... (spinedoc)
AFR sells LT4 heads I'm fairly certain.
I would go with some nice aftermarket heads, a new cam, and a pair of headers. 400 hp should be no problem whatsoever. Would expect at least 450!
-Steve
-Steve
