How Long Should 76 Vette Fast Idle
When first starting it goes to fast idle, idle speed is okay but it takes 5 minutes before it will kick down to normal idle seems like a long time for car to warm up is their something I can do to reduce this time? or is something not working right? I prefer not to put it in gear until it is off of high idle. Thanks for your help
Re: How Long Should 76 Vette Fast Idle (77-C3 & 89-C4)
My idle speeds are fine but how long the car fast idles is my question is 5 minutes to long when outside temp is 75 degrees
Location: Swords Check/Saws Check/Clubs Check/Claws Check/Hatred Check/Anger Check/Murmaid Check/Murder Check
Cruise-In IV Veteran
Cruise-In VI Veteran
Re: How Long Should 76 Vette Fast Idle (cell2each)
Might need to adjust the choke. Mine will take 1-2 minutes when it's warm outside but up to five minutes when it's cold.
