Project update... new gauges and fuse block
Old 09-23-2003, 11:03 AM
phoenix
Support Corvetteforum!
phoenix's Avatar
Default Project update... new gauges and fuse block
Well, after wasting money on old gauges and trying to get the crappy wiring to work with the new stereo, TPI, high output alternator etc....
I finally said WTF and sucked it up. I bought all new gauges from classic gauges, new wiring harness for the gauges and a new modern fuse block.
I'm almost done with the gauge install and then I have to address the spaghetti of the wiring system to hook all the old wires up to the new fuse block while removing the unused and blown wires.
One step forward, three steps back.
I'll post pics of the gauges when I finish fabricating brackets. :)
Old 09-23-2003, 11:36 AM
BSeery
BSeery's Avatar
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: Project update... new gauges and fuse block (phoenix)
:thumbs:
Old 09-23-2003, 11:39 AM
Fevre
Fevre's Avatar
You bring up a good point regarding the old wiring and tpi system, makes me think of running a second line and fuse block for the EFI system I have planned.
Old 09-23-2003, 01:05 PM
phoenix
phoenix's Avatar
Default Re: Project update... new gauges and fuse block (Fevre)
I knew that I had a problem when every time I stepped on the throttle, the radio would shut off. :(
To Project update... new gauges and fuse block
Quick Reply: Project update... new gauges and fuse block
