cable for autometer speedo revisited
Has anyone with a autometer guage found a cable that works? Please don't say the 68 cable I have one at the house and yes they fit the fittings on both ends but the cable doesn't engage the speedo. I'm getting quite frustrated with not having a working speedometer. Maybe I should call autometer and see what they suggest. Just wanted to hear from anyone who got this speedo guage to work.
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: cable for autometer speedo revisited (TTop Tony)
Is there an adapter on the back of the autometer that is needed ?
I know some VDO gages needed an adapter to go from the threaded end on the gage to the push-on style clip that GM uses.
Like I said before, I had a custom speedo cable made for my 76 with the autometer phantom speedometer. But I have abandoned my complete custom interior in favor of restoration of the dash and center console. (yea, I know a lot of money for a 76, but at least it will make me happy) Anyway, I will soon decide if I am going to use factory spedo and tach (I still have them). If a 76 auto cable will fit your transmission, I will sell it to you cheap.
--marc
ps a search on alta vista for "custom speedometer cable" seemed to yield some possible vendors.
[Modified by BigBadOrange, 5:54 PM 9/23/2003]
--marc
Re: cable for autometer speedo revisited (BigBadOrange)
Thanks BigBadOrange I appreciate the offer but knowing my luck the auto one won't work. But I will have to do some internet surfing and see what I get. I'd do it know but they keep wanting me to do this work thing. How rude :D
Years ago when i did my conversion i got my cable from these guys - I would call them - as i did - explain the application - i.e. corvette - 4 speed - Autometer, and they should be able to fix you up.
http://www.speedometerplus.com/speedometer_cable.htm
Re: cable for autometer speedo revisited (fauxrs)
Thanks fauxrs I'll give them a shot.
I've been meaning to ask you about your 5 speed tremec. My transmission has been having problems lately and unfortunatly I just switched to a 3.7 rear gear. How does that 3.27 first gear on your tremek feel with the 3.7 gear?
Its insane to use a word, I'm sure I could climb a phone pole in that gear :lol: - at WOT I am only in it to maybe 35-40 mph so you can imagine im not there long. also - huge long strips of rubber are possible if I so desire it. but then again i usually run out of R's before too much is put on the road.
2nd and 3rd pull like gangbusters, they feel terrific - an absolute day and night compared to the close ratio 4 speed. Of course 4th gear is the same and 5th....sweet - cruising on the freeway at 2500 rpm going about 75 is just perfect - compared to the 3500 I would have done before the swap.
That doesn't sound too bad I thought first gear would be almost unusable with the 3.7's. How bad is the jump from first (3.27) to second(1.98). Does your engine bog any? Maybe I can swing a tremec after all. The richmond 6 speed was a bit pricey for my tastes. Thanks for replying.
Not unusable, but usable for only a short bit, the 1-2 shift is a big jump yes but it doenst lug the motor at all, as after the shift i am still in the power band.
To be perfectly honest the 1st gear (or rear gear) couldnt get any lower before it became useless.
I figured the shift would lug the motor but its good hearing from someone who has actually done it. I'll see if I can find someone to fix my super T10. If not at least I have an option. I also called speedometer plus hopefully I can get my new speedo working. Thanks.
I bought a speedometer cable from lokar from a street rod shop. You can also get it at summit for about 54.00. You cut it to length. I have not installed it yet so can't tell you how it worked out.
Tim
Tim
Your better auto parts stores have a cable catalog that you can see pictures and descriptions. If you know how long and what ends you want it's just a matter of browsing the back pages.
Re: cable for autometer speedo revisited (markdtn)
I was able to use stock type cable I went to local aout parts store to get a shorter cable that stock since I also have a tremec the speedo gear on the trans is on the other side.I'm useing autometer silver super comp gauges.
