new demon carb and valve covers. have vacuum question
okay on the new demon, do i need to run a hose from the valve cover to the carb? or can i just sit two breathers up there? there are three holes in the valve covers, obviously one is for the oil cap.
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: new demon carb and valve covers. have vacuum question (munday)
you should run a PCV valve and breather like before.
St. Jude Contributor
munday,
Buy yourself a carb spacer that incorporates a PCV valve tube. Mr. Gasket makes a 1" spacer(w/ PCV tube) for the 4150 carb that you can buy from Summit, Jegs or probably locally at a speed shop. (Pt# 4945)
I've got a brand new one that I am not using if you would like to try it.
Re: new demon carb and valve covers. have vacuum question (bgrice)
yeah i would, will it clear the hood though? i'm using a 3inch drop base with a performer rpm
thanks
thanks
