If you could rebuild a 350, how would you do it?
Old 09-22-2003, 10:06 PM
LFZ
LFZ's Avatar
Default If you could rebuild a 350, how would you do it?
Say you got a 350/300hp old engine, and you wanted to rebuild it....what exact heads, cam, intake, pistons, and other stuff would you go with?? especially if you want something to sound mean and run on pump gas at the same time?
Old 09-22-2003, 10:47 PM
joeveto
joeveto's Avatar
Cruise-In IV Veteran
Cruise-In V Veteran
St. Jude Contributor
Default Re: If you could rebuild a 350, how would you do it? (Redshark6974)
Check out my homepage. I have a link to my engine page as well as the best engine combo page out there. This guy has hundreds of published and tested engine combos. It's part of what helped me come up with mine.
:cheers:
Old 09-22-2003, 11:42 PM
Glenn's 67 BB Vert
Glenn's 67 BB Vert's Avatar
Default Re: If you could rebuild a 350, how would you do it? (joeveto)
Could not find a link to anything engine wise but enjoyed the rest tho--?????--Glenn :chevy
Old 09-22-2003, 11:48 PM
MotorHead
MotorHead's Avatar
Location: Who says "Nothing is impossible" ? I've been doing nothing for years.
Default Re: If you could rebuild a 350, how would you do it? (Glenn's orange 69)
Not following what you want to do here, if you want a 300HP motor that's pretty simple rebuild any 350 put in flat top pistons a CC270H cam and your there or pretty close. :D
Old 09-23-2003, 04:19 AM
blackbirdpilot
blackbirdpilot's Avatar
I would say it would depend on what final out come you want. If you are going for a numbers matching deal, attempting to look factory stock etc, or just to get a car running to just drive.
I have built a few chevy motors over the years. I like to use quality parts and go through everything, never skimp at any point. But, now if I just want a good running performer and not worried about number matching, I will buy a crate motor from Chevy. Cheaper, quicker and even comes with a waranty. LT1, ZZ3, zzz4 or go crazy and get ZZ430! What ever. I just dont think that I will rebuild a SB chevy again, unless it has to be a show car. Not likely. I would rather drive and enjoy the car.
JMHO
Marco
:flag :thumbs:
Old 09-23-2003, 08:39 AM
Smitty's75
Smitty's75's Avatar
Default Re: If you could rebuild a 350, how would you do it? (blackbirdpilot)
I'm gathering the parts for my 75 to duplicate the 70 LT1 motor,,already have the original cam in the GM tube,,,the heads are on E-bay for about $300 all the time,,intake is easy,,so is the Holley carb,,all can be found on E-Bay,,the Lt1 was an awesome street motor and 370 HP is enough for me!
Old 09-23-2003, 09:13 AM
bhmyers
bhmyers's Avatar
Stroke it. AFR heads 750 carb 290 cam. and you will light the tires up.
Old 09-23-2003, 11:45 AM
BSeery
BSeery's Avatar
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Default Re: If you could rebuild a 350, how would you do it? (bhmyers)
383, roller cam, 10.1 compression, aluminum heads, air gap intake, 750 Edelbrock, headers and good quality parts (bearings, gaskets, bolts).
Old 09-23-2003, 12:11 PM
Scooter70
Scooter70's Avatar
Default Re: If you could rebuild a 350, how would you do it? (BSeery)
Sounds like what I've been pondering for the last year or so.... depending on how mild or wild you go with a cam.... anywhere from 440hp/505ft-lbs to 520hp/490ft-lbs!!
Old 09-23-2003, 02:07 PM
jrzvette
jrzvette's Avatar
Location: The reason time exists is so everything doesn't happen at once
Default Re: If you could rebuild a 350, how would you do it? (Smitty's75)
Don't forget, in 1970 they published gross HP numbers not net. Also remember that valve adjustments with solid lifters can quickly lose its "fun factor".
Old 09-23-2003, 02:13 PM
flood
flood's Avatar
Default Re: If you could rebuild a 350, how would you do it? (6t9l4t6)
I really like the FI unit on the Ramjet. I think a FI motor would be sweet.
Old 09-23-2003, 02:44 PM
sb69coupe
sb69coupe's Avatar
If it were me, for that car, I'd rebuild it back to stock. Where is Olivier's "beating the dead horse" smiley when I need it?
:banghead:
Old 09-23-2003, 02:50 PM
LFZ
LFZ's Avatar
Default Re: If you could rebuild a 350, how would you do it? (sb69coupe)
:banghead:
sorry...i can't help it if i'm ANTI-STOCK. I like big wheels, loud stereos and speed..besides, a crate motor is going in the car, i was just thinking about rebuilding the old motor anyways for maybe somthing else...
Old 09-23-2003, 04:37 PM
Smitty's75
Smitty's75's Avatar
Solids can easily be maintained by keeping the revs down, using poly locks, only put about 3000 on the car a year, the maintenance on solid lifters is highly exaggerated,,,been there done that!!!
Old 09-26-2003, 08:43 PM
joeveto
joeveto's Avatar
Cruise-In V Veteran
At the bottom, on the right hand side, click on "My engine page."
Also, there is a link below that, for engine combos.
Old 09-27-2003, 03:22 AM
pillowmeto
pillowmeto's Avatar
a very big blower and fuel injection.
MAtt
Old 09-27-2003, 04:35 AM
rainman69
rainman69's Avatar
I would build the 11:1 350 destroker from a car mag a few years back. Take a 400 SBC block, use f*rd rods, badabing, 350ci, 11:1, 87 octane...400ish HP.
To If you could rebuild a 350, how would you do it?
Old 09-27-2003, 08:29 AM
Ganey
Ganey's Avatar
Sto*k is a bad word to me.
Assuming the 69 4 spd., HE268H is the Min. cam & XE268 the Max. w/o rebuild, balance & blueprint. HE268H is max. for stock valve springs & good for over 300 HP (even w/ Action+ intake) w/ good exhaust. Many good heads are available.
W/ headers you could run HE270H for example. TRW forged & Al. non egr intake.
Old 09-27-2003, 08:32 AM
Ganey
Ganey's Avatar
Default Re: If you could rebuild a 350, how would you do it? (rainman69)
PS
rainman69
Their theory was bad.
Old 09-29-2003, 09:55 PM
pillowmeto
pillowmeto's Avatar
for the street
a fuel injected 355 with 9.5 or 10-1 compression and ported everything along with a singleplane intake if i could fit it under the hood.
for the track or street w/ race gas
side pipes
a fuel injected or davinci carburated 355 or roller cammed 383
tunnel ram with the injecters seated in that instead of those converted carb units
A really big blower
side pipes
the above are given i had the money, which i dont, cause if i did id have a 427
MAtt
Quick Reply: If you could rebuild a 350, how would you do it?
