Ques on factory paint method
I noticed while I'm trying to find my electrical problem that my '75 (St. Louis plant) has body paint on the front harness. I thought the body was painted before it was installed on the frame. Unless I'm wrong this could mean that the front end was repaired at some point and repainted. Not that this solves my problem - but it did serve to get me off track when I found some spade connectors up there that are not attached to anything, just hanging loose. So I wanted to see what's what and noticed the paint overspray.....
Re: Ques on factory paint method (KenSny)
Body was painted and blackout applied before the body was delivered to the assembly line. It was very common for small areas of the car to need touch-up as the car entered final inspection. Those cars were pulled off the line and sent to a special area for the touch-up work to be performed. If you're fairly certain that the car is wearing the original paint, then I'd assume that this is the reason for the overspray you found.
Re: Ques on factory paint method (sb69coupe)
Not certain, but the car has 80k on it and I'm the second titled owner. The paint does look original. Maybe a little too good in front tho. Guess I will take a look at the body work under there to see if there's any patches or repair areas.
