Snack
Snack
Took a test ride tonight after dark to check out the new halogen beams. I also tightened up the loose bolts and adjusted the stop bolts. No more headlight bouncs and shinin brighter than ever. Even had some rice for a snack on the way home. BRUP!!! Thank you sir may I have another?
:steering: :D
:steering: :D
Re: Snack (ray77vette)
I just went out to one of the local discount auto parts stores and got 4 halogen replace beams. $8 each for a total of $32.
St. Jude Donor '08
Almost all auto parts stores should have them. If you know your headlight number just put an H in front of the number most of the time. example
my Outer is 4000 change to H5006. Inner 5001 go to H5001 :cheers:
[Modified by guppie, 6:17 PM 9/23/2003]
