Rear End (square wheel) problem.....farther investigation
Does it damage anything to put a Vette in gear while it is up on jack stands?
While I was searching for a problem in the rear end of my Vette today....I started it while I had it on the jack stands and then I put it in drive and gentlely let out on the brake...........I discovered that the driver's side moved but the passanger's side didn't. The passanger's side is the side I'm hearing and feeling everything.......My guess..........wheel bearing.......I'm I in the right area? :smash:
Re: Rear End (square wheel) problem.....farther investigation (79VetteGirl)
I thought all Vettes came with posi rears. If your passenger side did not move it sounds like your posi is out for starters. I would not want to run the wheels while on stands because of the severe angle the half shafts are in while hanging. This could be very hard on the U joints. If you want to check the bearing, try to move the wheel from 3 oclock to 9 oclock and see if you have alot of movement. Craig
A CI-6 Car Show Winner
I ran mine at an idle today while on stands to investigate a rear rotor run out problem. I found my spindle is bent :mad I don't believe running it in gear at an idle for a very short period of time will harm anything. I do believe your clutch pack or gear cluster is out in your rear end however. When I turn one wheel the other wheel also turns in the same direction. You must have some serious problems in the rear end. I know of a good guy in Beloit, Wisconsin for rear ends, e-mail me if you need one and would like to reach him.
I agree with big fish, sounds like it is internal to the rear end not the wheel bearing but check it while you have it up off the ground. It could be the bad bearing has that side locked up and not allowing it to turn. Check the wheel bearing first and go from there.
:iagree: YBNormal...drive a vette
www.angelfire.com/al/swhite7/vette.html
It's not a good idea to do that.. As others stated. Too much anlge for the "U" joints. Side to side play can be worn side yokes (common problem) There's lots of onfo on that. There should be Almost no in-out movement of the yoke at the differential .
Re: Rear End (The Money Pit)
I don't think this was mentioned before but if the wheel was locked up it could be an e-brake problem. If the e-brake hardware has broken it will let the shoes expand and drag or possibly lock up. I would remove the rotor and check this out first. I didn't realize the wheel was locked up before so your posi may be fine. Good Luck, Craig
[Modified by CF6873, 9:10 PM 9/21/2003]
