My Engine Plans
My Engine Plans
Unless I get lucky and find a BB Vette worth buying in my price range, this is my plans for the motor.
383 or 377-(400 w/327 crank and rods) Forged
10.5:1 Forged pistons
AFR 210 heads (ported to 300cfm@600)
Victor jr. intake (port matched)
Holley 750 (vac sec)
Comp Cams hydraulic roller, with 236/242° of duration @ 0.050 in. lift, and 0.520/0.540 in. lift
1.6 roller rockers (should raise the cam lift ratio)
This combo should still run on pump gas and produce 500 or above HP while still allowing me to use the AC. Of course a 3000 stall in a 700R4 is my trans of choice. If I calculated it all out right I should be able to drive it to the track and still runs 10s. Of course I could get greedy and spray 250 in it and theres no telling what I will run but that is still a ways away. Tha motor will cost right arouns 4000$ to build so thats not too bad.
Any opinions or thoughts on any or all of this?
Jerry
Jerry
Re: My Engine Plans (Shark Attack)
Sounds like a good combo.
Nearly identical to mine...and it runs GREAT!
Mine is a 406 however.
Same Cam
AFR195's
10.4:1CR
4000rpm stall
Mighty Demon 750
Victor Jr.
I run the 1.6 rockers on the intake for .555" lift and 1.5's on the exhaust for .540". The I/E ratio of these heads is high, so you can gain a few hp by opening the intake a little more. This is also the basis of the arguement that with such a a high I/E ratio a single pattern cam is more effective.
If you want more info on my build of the 406 i'll IM or Email you.
As is I can do a "burnout" at 40mph.... :reddevil
As for your "total," I think that is a little low. I have over $8000 into mine, excluding the little things. :eek:
Good Luck!
:cheers:
[Modified by VETDRMS, 6:27 PM 9/20/2003]
Same Cam
AFR195's
10.4:1CR
4000rpm stall
Mighty Demon 750
Victor Jr.
Good Luck!
:cheers:
Re: My Engine Plans (VETDRMS)
383 Stroker
4bolt main
forged eagle I beam rods
forged SRP dome pistons
internally balanced
11.5:1
1,599.
CCA-12-433-8 Chevrolet: 262-400, 288/294 degrees advertised duration, retro-fit, hydraulic roller, Xtreme Energy camshaft $239.95
Pete jackson gear drive
PJJ-327-1C-N Small Chevy: 262-400, "noisy" gear drive
$142.95
Pro top line
123 4600 20K4
Assem. with Roller Springs 1.550" Dual w/dampner 220#@1.950" 1
$1,380
Roller Rockers
CCA-1304-16 Chevrolet: 265-400, 1.52 ratio, 7/16 in. rocker arm stud, Pro Magnum, roller, rocker arms
$265.69
Of course that not the exact combo that I posted and it will of course need more like the carb, dist ect... but it gets me in the ballpark at $3627.59
I know it will be closer to 5K or a little over but not by much
Jerry
Received 1,875 Likes
2017 C2 of Year Finalist
I think it will cost a little more too. We still gotta get some lifters(and hyd roller lifters are ridiculous!), machine work, gaskets, pushrods, intake, carb, dist. oil pan/pump/windage tray, balancer etc etc.
But you can really save lots of $$$ by doing shopping around and even swap meets. Houston has some good ones! Lots of small block parts out there when folks decide to move up to another level whether it's a stouter small block or whatever.
JIM
JIM
Re: My Engine Plans (427Hotrod)
I've got a 406 that cost me $4500 to build the first time.I run a flat hydraulic cam,which I'd recommend you do as well.Once you dial in the combo,change over to roller if you want.The intake is up to you,but in all dyno pulls and build ups I'd read,the RPM is the manifold of choice up to 5000,with a single plane gaining only a few horses above that.(Like 10-15)
Check out my website for details.
Moneypit, intake choice should be considered depending on which type of transmission you have. If you have an automatic, then a dual plane is a good choice. If you have a stick, then you should consider a single plane. Here's the reason: With an auto the rpms drop further when shifting so the rpms are lower in the power band. A dual plane has longer runners (much like the TPI units in the 80's) to help with torque. When you shift a stick, the rpms don't drop as far so you you don't have to be as concerned with the longer runners because your already in a higher rpm range. JOhn Lingenfelters "On modifying small-block Chevy Engines explanes this very well and has graphs soing the differences. All that said, the Edelbrock RPM intake is an excellent intake all around ;) .
St. Jude Contributor
Shark Attack...
I'd think about going with a double roller chain and can the idea of a gear drive set-up. I had a set come apart on a 468 that wasted the motor. Thought maybe we had broke the cam when we pulled the valve covers and none of the valve train would move when turning the engine over. It was a mess inside after taking everything apart.
