N2O shot level?..
Re: N2O shot level?.. (Corey 68)
Well,the bottom is a 2 bolt main with ARP bolts,cast crank,3/8 rods with ARPs(thinking of buying Eagle or Scat rods) and TRW 2349 slugs..I really like the look of the Fogger systems :skep: :cheers: :cheers:
Re: N2O shot level?.. (BB wowbagger)
The TRW's are forged, right? What about the connecting rods (when you say ARP's, I'm assuming you mean it has ARP fasteners on it). If the con rods are just reconditioned stock and the crank is a likewise setup, you probably don't want to run over 100HP shot. If the crank is old, the fatigue life of the metal is unkown, and you don't want to push it. If you had newer/forged reciprocating components, I'd say go for the fogger. You can always install the fogger and just put very small jets in it :D
Rpm kills motors not boost (at least a 100 shot ) I have run a 100 shot through my Fogger on a 454. .019 fuel and .019 NOS jets at 6 lbs flowing pressure. A 100 shot on your motor would be no problem, before you run it learn a little about NOS. You can definitley feel a 100 shot on a 454
1. depends on whether or not the motor was built to handle it
2. it's a 454! you don't need nitrous. just my opion, which may not count for much
