Can oil leak from the fuel pump area?
Guest
Posts: n/a
While under the car, I noticed engine oil on the bottom of the fuel pump assembly, the block around the fuel pump attachment, and it's blowing back onto the rest of the block and starter. I wiped it down good and took a short drive then rechecked it. IT IS NOT coming from the front seal (replaced in April) but looks as if it is leaking from around the fuel pump attachment area. Can oil leak here and has anybody else had this problem? How difficult is it getting to the fuel pump and removing it?
[Modified by Rick Church, 8:33 PM 9/19/2003]
Re: Can oil leak from the fuel pump area? (Rick Church)
Yes it can, oil flows down the pump rod and then pools in the pump area and then drains into the block/pan. Another thing to look at is they a bolt in the tapped hole on the front of the block directly in line with the pump rod, it is tapped straight through to the pump area inside the block.
Absolutely. Also there are two gaskets in that location for small blocks. There is a gasket for the pump, and a gasket for the mounting plate behind it. Always replace both when removing the pump and avoid the hassle.
PITA IMHO. If you do take it out here are a couple tips for reinstall:
1. Make sure the fuel pump lobe is NOT pushing the rod out, might have to bump the eng over a little to get it to rotate out of the way.
2. Use a bolt in the the upper of the 2 holes in front of the block right near the pump, the upper one is tapped all the way through into the pump area. The bolt has to be long enough to hit the rod, use this to keep the rod up riding on the cam so it won't drop down in the way of the fuel pump arm. If you have no bolt there now, use a short bolt that won't interfere with rod and use rtv sealant or thread tape on it so it won't leak oil.
Good luck!
[Modified by Fevre, 3:49 PM 9/19/2003]
Good luck!
Before you go removing your fuel pump, check to see that you are not leaking oil from the front seal. I always had oil on the bottom of the fuel pump and in that general vicinity. Oil from the front seal is thrown in that direction. I changed the front oil seal, and voila, no more oil under the fuel pump.
Cruise-In VI Veteran
Cruise-In VII Veteran
Rick actually it isn't that hard if you pull the right front tire and go in over the A-arm. There is a clear shot directly to the bolts a socket and an extension and your home free. I learned this the hard way, after spending 45 minutes getting one bolt out from the bottom. I got out from under the car and just happened to look over the front rotor (I already had the wheels off.) and saw the opening. 10 minutes later the new pump was on.
The engine was cold so I used a big glob of grease to hold the pump rod in place. Ditto on replacing both gaskets!
Also a set of tubing wrenches really help when disconnecting the fuel lines from the pump.
And yes take off the front tire to get a straight shot at the bolts.
Hardest part is keeping the rod up into the block while replacing the fuel
pump. Keep at it and you'll get it in. Check it good for leaks after. Goodluck.
:thumbs: :seeya
Re: Can oil leak from the fuel pump area? (DMONSVETTE)
pump.
pump.
Rick,
definitely check the bolt hole in front of the fuel pump on the block like Fevre said. You may need to put a (very short) bolt in it.
Scott
Scott
