Looking for some info about 454 engines
I'm looking to buy a 454 engine for my next vette project. I have two to pick from:
454 complete, needs rebuilt, $450
454, new generation, 4 bolt main, long block. $300
I'm calling on both engines tomorrow and am leaning towards the 454 4 bolt main engine. What is the differance between the two? old Gen vs New gen.
Which one would you go with? Both are priced right.
Re: Looking for some info about 454 engines (Mr D.)
Both seem dirt cheap to me, you'll most likely have to rebuild them both.....what is meant by complete????? Does it include the water pump, fuel pump, starter, ignition, carb, exhaust, intake, flywheel etc....
...to transplant a big block into a Vette you'll need a new pulley set up, radiator, half shafts, flywheel, etc.....
I'm not savy to the term new generation.....your best bet is to inspect both engines and write down and decode their block casting number, casting date number (located at the rear of the block on driver or passenger side) and the engine suffix code and partial VIN (located below the heads on the front passenger side--note that this number may not be there if the block has been milled or rebuilt).........this will help identify what car or truck the motor was originally assembled for and the base HP and torque--not all big blocks are HOT.........
Do the same with intake and heads......post the numbers here if you need help decoding......
Senior Member since 1492
I think the Gen V's may not have a provision for a mechanical fuel pump. Better check that if that matters to you. Meaning you'd need to use an electric fuel pump. Mine is an '87 and classed as a Mark IV (which ran from '65-'89) and I'm able to use a Fel-pro one piece oil pan gasket.
As said earlier, get the serial numbers and go to: http://www.mortec.com/bbc.htm that will narrow down the description somewhat. You should be safe with either since no 454's are listed as having a "tall" deck. I extracted my 454 from an '87 Suburban and it turned out to be a 4-bolt. :hurray:
I'd get the 4-bolt and go with an electric FP if needed. IMO 4 is better than two and you'll save yourself some work not having to dissassemble the other block. Mine was complete also and was a chore to take apart....although I learned alot along the way. :chevy
Good luck & keep us posted.....we love pics too! :D
[Modified by 1970 Stingray, 4:52 AM 9/19/2003]
Re: Looking for some info about 454 engines (1970 Stingray)
Thanks everyone. I just called on the complete engine and it was sold. The other I'm looking at tonight. It is a one piece rear seal, (would this be a Gen VI) out of a boat, never been apart. While I'm fine with this setup my concern is: Can I use this model in a C-3 4-sp car? oil pan, clutch hook up, ect ect. I will do a complete rebuild on this engine so the cam, pistions ect I don't care about. It does have the small (smallet than oval) port heads which I won't be able to use (or so I'm told).
I guess I'm looking at 4-bolt main block, crank, rods, maybe some head hardware for $300 (I think he will take $250) Sounds like a deal to me.
Re: Looking for some info about 454 engines (GDaina)
might want to be careful on a boat engine, because if the motor ran an open cooling system (salt water in salt water out) there is a chance that rust in the cooling passages could be rusting the block away from the inside out.
St. Jude Contributor
Re: Looking for some info about 454 engines (J. Swisher)
I rebuilt a number of 454's out of shrimp boats on the side while I was in New Orleans and I quit messing with them after the last engine that came in that kept stripping out head bolts. Even heli-coils were useless. And it was useless to bake out a block and expect that you could get the cake-up inside gone. Hit the block with a brass hammer and you could hear the crumbling inside. NO ONE wants a block exposed to salt water..... PERIOD!!!!
