help installing fuel line hoses to mechanical fuel pump???
This should be so easy...but its not. In fact, I feel kind of stupid even asking for help on this. I have the replacement mechanical fuel pump installed and was installing the rubber hoses from the pump to the fuel lines. The smaller diameter hose installed with no problem, however, the larger hose is more difficult. When I connect both ends of the larger hose...the fuel inlet hose... the hose kinks at the connection to the pump. It looks like the angle coming off the pump connection and rising up to the metal fuel line is tight which is causing the kink. I tried different lengths and twisting the hose in different directions to no avail. I did not pay to much attention to this connection when I uninstalled the pump because I thought this was so easy. Such a simple little thing yet so much aggrevation. I want my car running this weekend while the weather is good. Any suggestions are greatly appreciated.
Re: help installing fuel line hoses to mechanical fuel pump??? (Frankenvette)
This is the main reason that so many vendors carry these lines in their catalogs. It is a preformed hose that is pre-bent in the right places to avoid kinking. I have used a piece of regular rubber gas line in the past, but you have to use a longer piece than original to allow the hose to make the bends without kinking. I haven't done it in a while, I keep a couple of replacements on hand, but if you use a good quality piece of multi-ply hose it should work.
Good luck and if all else fails; you can probably obtain one from a local Chevrolet dealer quickly.
GUSTO
GUSTO
Re: help installing fuel line hoses to mechanical fuel pump??? (GUSTO14)
I did not know this was available preformed. Maybe that is why I'm getting the kink. I did upgrade to a stronger hose and still it kinked. I'll call the local chevy dealer and see if they have one available. Thanks!!
:iagree:
I replaced mine on an 81 two weeks ago. Got the hose from Napa. Had to make the hose about six inches longer than the original so it wouldn't kink. Corvette Central sells the preformed for about 12 bucks.
:iagree:
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
When I replaced my fuel pump, I still had the full metal line from the pump to the carb. The nuts were rusted and they twisted the line. I went to autozone and bought a new 30" metal line and borrowed their bender. It took some time and trial and error, but I was able to bend the line without any problems.
