Can someone splain how an electric choke works?
St. Jude Contributor
When I start my vette in the mornings, I have to play with the throttle forever to get it to warm up. It ends up dying a few times then I can drive with no problems. I know it is the electric choke, but I dont know how it works, so there is NO way I can trouble shoot it. :mad :confused:
Re: Can someone splain how an electric choke works? (RLaFarge)
An electric choke works the same as a conventional non-electric choke, but instead of using heat from the engine to warm the spring and open the choke, an electric choke has a heating element to do the same.
Sound like your choke is out of adjustment.
Once you get the choke adjusted right you will need to adjust the fast idle.
Good luck!
:cheers:
Good luck!
:cheers:
Re: Can someone splain how an electric choke works? (Ken74Conv)
Good luck!
:cheers:
Good luck!
:cheers:
Been a while since I used my carb with the choke but you should be able to unscrew the three screws on the black plastic circle and rotate it to pull the choke further closed. Do this when the car is cold, not running and the key is on. Believe it labled with an arrow(s) pointing in the direction(s) of lean and/or rich telling which way to rotate it depending on your condition, in your case rotate toward rich which will close it more when it is first engaged.
And also there's the choke pull-off dashpot. Or vacuum motor if you prefer.
It recieves vacuum when the engine starts, to pull back (to allow more air flow) what would otherwise be a closed choke plate or butterfly a specified amt.
This can be adjusted also. This and fast idle rpm setting will make your engine run better when cold. :D
im not really having any problems with mine but how do i either remove it from my edlebrock performer or connect it and which is better.
MAtt
MAtt
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: Can someone splain how an electric choke works? (pillowmeto)
Matt, if you have an electric choke on your carb and you want it to start a little easier and run smoother when it's cold, then you need to hook it up. You should hook it to a switched 12V supply, that is 12V that is only hot when the key is in the run position. Some people use the windshield wiper circuit since it is fairly close to tap into, other people run a seperate wire from the fuse panel. Which ever is easier for you to do.
If you don't have any use for the choke then you can leave it unhooked, but the choke flapper is only going to open completely up by engine vacuum and will at least partially restrict air flow into the carb.
