Found my build sheet
Last night I was crawling around underneath and seen a scrap of paper sticking out from the heat shield that covers the bottom of the differential and the leaf spring. Removed the shield and there it was, about 70% readable.
Re: Found my build sheet (Jeff78)
Jeff,
Check out this older thread if you need help reading that tank sticker.
http://forums.corvetteforum.com/zerothread?id=633190
You guys kill me from Michigan and Minnesota with your "I seen it" :lol: The rest of the country "saw it". Anyway, I couldnt help but poke fun. I guess someones going to take a crack at the Southeners expressions now.
Re: Found my build sheet (72vetteman)
Hey, I found mine in the same place last week while replacing the 9 leaf with a 7 leaf on my '76. Sadly it was quite oil soaked torn and completely unreadable. Tried to clean only to shred it further. Ended up throwing it away. :sad:
Re: Found my build sheet (PigPen)
Found mine on the gas tank a few years ago...felt pretty lucky, verified the radio delete status of my car. It was in pretty rough shape but I still have it and a couple of copies, just in case.
Jeff
Jeff
Re: Found my build sheet (no_radio)
I've had 3 C3s and none have had a build sheet (as far as I could tell.) Never dropped the tanks, but looked with a light and telescopic mirror.
Sammy
Sammy
