Engine # verses VIN # ?
Re: Engine # verses VIN # ? (Ice_Fire)
The VIN on the windshield pillar will have the same numbers on the front of the engine. Just look on the engine on the passenger side in front of the head where it attaches to the engine.
Re: Engine # verses VIN # ? (WEASEL13)
An orignal pad will be unpainted as well have the tail end of the VIN + the suffix for your engine/trans combo.
( 1=Chevy, 3=1973, S=St Louis, 4=place holder, 99999=build sequence)
tom...
Re: Engine # verses VIN # ? (Tom73)
Also remember any-one can re-stamp and engine block or any other item. If you are buying a numbers matching car then take it to a pro. Just because the engine numbers matches that means very little unlesss all the other numbers also match. I have been told that 90% of the so-called numbers matching old cars are fakes. Where there is money there are fakes . Good luck
