Checking power steering fluid
My power steering cap is directly below the alternator bracket with about an inch of clearance between them, is this correct? How do I get the cap out to check the fluid level? I can unscrew the cap but it seems like there is not enough room to remove it. Any help would be greatly appreciated. :confused:
Location: The reason time exists is so everything doesn't happen at once
Re: Checking power steering fluid (Ice_Fire)
My is the same. just unscrew it. tip towards the rad and lift it out Tight squeeze but it will come out. :thumbs:
And I suggest you get a funnel with a very long neck for when you have to add fluid.
