Dash lights went dead???
Hey, anybody have this happen? All my dash lights went dead...except for the brights indicator !! :confused:
I checked the fuse, but all are giving power....
I just wanted to check before tearing the dash apart!?! Any input would be MOST welcome! :grouphug:
Re: Dash lights went dead??? (69Rat)
I found out last week that taking the dash apart is not a fun thingy! :skep:
Re: Dash lights went dead??? (VetticusSupersonicus)
Nope. It's the switch.
Takes about 30 min. (2 beers) to replace. The contact on the dimmer spring get corroded, and the dash lights go out.
:cheers:
:cheers:
St. Jude Contributor
Re: Dash lights went dead??? (Bob Turner)
I pulled my light switch out and hosed it down with some circuit cleaner.
You can get it from Radio Shack. Over time, carbon builds up on the contact.
:smash:
:smash:
Re: Dash lights went dead??? (Brettmc)
Headlight switch? What trick do you use to replace that in 30 mins?
Brett :thumbs:
Brett :thumbs:
I'm in the same boat. The previous owner told me it's the dimmer switch rheostat that's gone bad. Sounds like this is a common problem.
Yup Headlight switch. Mine did it too and even the new one is a little weaker than i like. Probably a bad ground for me as stated above.
Re: Dash lights went dead??? (Armstrong)
Cool... Thanks for all the replys! :cheers:
Damn.. I hope the switch side of the dash is easier then the center section.. that SUCKED!! :banghead:
