How do I raise the radiator shroud?
Got some fan rubbing at idle if the car is sitting on an incline. Not cool. How do I raise the fan shroud?
TIA.
-Steve
TIA.
-Steve
Re: How do I raise the radiator shroud? (Pacin'California)
If you have all the "right stuff" on the car, I'd check the motor mounts to make sure the engine isn't loose, causing the fan to hit the shroud. Chuck
Re: How do I raise the radiator shroud? (Chuck Gongloff)
Is there a way to lift the shroud? Or am I looking at making the tranny mount "thicker"?
-Steve
Steve
You might check your trans mount, if it is loose or has some play the eng might be shifting/tilting when on an incline.
Re: How do I raise the radiator shroud? (Fevre)
Steve
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Oldtimer
This happened to me once i changed my motor mounts and trans mount. You have to adjust the mounts of the shroud down at the radiator support and up top where it bolts to the support.
