prefered 69 BB spark plugs
Old 09-16-2003, 08:45 PM
Red69
Red69's Avatar
Default prefered 69 BB spark plugs
Hey all...
... I need to replace the plugs in the BB. Previous owner used R44xls... Book calls for R43N.... Was wondering what other plugs are being run... with good results!! Anyone know the difference btwn N and XLS?
Thanks
Old 09-16-2003, 09:29 PM
marky mark
marky mark's Avatar
Default Re: prefered 69 BB spark plugs (Red69)
N is I guess is for non-resistor plug which I believe are the recommended plug. I have used R-43 XLS with much success. It is listed in many manuals as the current plug of choice. R-44XLS is fine too, just a hotter plug. I tried a set of non resistor plugs in it also and could tell no difference either way.
Gap at .035 and you are good to go. Have fun!
Regards, Mark
Old 09-16-2003, 10:05 PM
69Rat
69Rat's Avatar
Hey Mark.. I run the R44nxls... but I run the gap at 50... I'm running a Mallory Unilite with a pro coil, and Mallory VII CD.... It picked up a bit of torq, and 2 mpg over a 35gap!! It your running a modern ignition.. widen the gap and play with it to see what your beastie likes!
:cheers:
Old 09-16-2003, 11:28 PM
LAvetteman
LAvetteman's Avatar
St. Jude Contributor
I have used the recommended AC plugs but recently switched to accell shorty plugs due to header closeness. Runs no different, except for the plugs and wires being away from the headers.
Old 09-16-2003, 11:55 PM
Red69
Red69's Avatar
Default Re: prefered 69 BB spark plugs (LAvetteman)
I'm running a stock set up. Got any prefered vendors for ignition parts?
Thanks
[Modified by Red69, 12:14 AM 9/17/2003]
Old 09-17-2003, 01:52 PM
LAvetteman
LAvetteman's Avatar
Sure, for Delco parts I like GM parts direct. They are a forum supprting vendor.(they help pay for this place)
http://www.gmpartsdirect.com/
Old 09-17-2003, 02:26 PM
bence13_33
bence13_33's Avatar
I usually run 43XLS's on my 454 and they work fine.
To prefered 69 BB spark plugs
Quick Reply: prefered 69 BB spark plugs
