Does anyone have aluminum driveshafts/halfshafts??
Re: Does anyone have aluminum driveshafts/halfshafts?? (Crickett)
You should get some responses. I know that Van Steel sells them. I think a few guys in here were buying or considering them.
Sure do! Everything I read about aluminum driveshafts said do it. They actually flex to absorb the shock of hard launches. I went with 3" which just fit in the tunnel.
http://www.dennysdriveshaft.com they gots aluminum!
I had aluminium Half shafts in my 69 .They worked well with traction of 335 rear tires. Aluminium driveshaft is another thing because of lack of tunnel space.Aluminum shaft needs to be larger diameter for same strength.
Re: Does anyone have aluminum driveshafts/halfshafts?? (fireball)
Re: Does anyone have aluminum driveshafts/halfshafts?? (stinky)
Premium Supporting Vendor
I'm starting to now make aluminum drive shafts and half shafts.
1/2 shafts - $400
Driveshafts - $425
These have Brute Force U-Joints.
For Spicer Joints they are
$425. for the 1/2 shafts
$450 for the driveshaft
Free Shipping!!
1/2 shafts - $400
Driveshafts - $425
Free Shipping!!
Re: Does anyone have aluminum driveshafts/halfshafts?? (Van Steel)
1/2 shafts - $400
Driveshafts - $425
Free Shipping!!
1/2 shafts - $400
Driveshafts - $425
Free Shipping!!
Sweet deal! What kinda of alum are they made of?? Do they have a warranty. :thumbs:
They are made out of 6061-T6 Aluminum. We will warranty them for 1 year povided you have 600HP or below
Thanks for your help!!!!! :thumbs:
Cruise-In VII Veteran
St. Jude Donor '07
I used a 88 vette driveshaft and cut it down a couple of inches. Works fine and shaved about 3 pounds off.
quote
Another question for ya. How does that compare which 1330/1350 grade alum.
Never heard of it. I've heard of 1330 and 1350 series u-joints but not aluminum. Sorry. If your asking how the aluminum holds up w/those joints, I'de say just like any other u-joint would. They will hold well.
Re: Does anyone have aluminum driveshafts/halfshafts?? (flynhi)
Not sure. I have never had a set made before. My driveshaft guy just told me that he could start making them for us.
