blowing TS fuse what to check for?
Ever since replacing Pertronix and using hazards for 30 min, my turn signal fuse blows every time engine starts. If I dont start engine, signals work fine, but if I turn key forward, flash, it blows. already replaced flasher can. Hazards still work fine.
Im not good with electronics so I checked with MM across fuse for amps but blew MM fuse. So question is what setting should I be using on MM to learn anything about the problem? THX
Re: blowing TS fuse what to check for? (Surfer69)
Turned out to be backup switch wire touching header pipe and shorting out.
Thanks everyone.
Thanks everyone.
