Holley 4175 or 4011?
Cruise-In III Veteran
I'd like to try a spread bore carb to see if it's better than my Edelbrock square bore.
Holleys seem to be a better choice than Q-Jets, so which might be the more reasonale model? 4175 or 4011?
I emailed Holley tech for their advice, and once again, they were noncommital.
Cruise-In VI Veteran
Cruise-In VII Veteran
Re: Holley 4175 or 4011? (AlwaysWave)
I have a 4011 and it is a pretty good carb, BUT!!! the angle of the dual fuel feed lines makes it extremely hard to find an drop base air cleaner that will fit over it. I think the 4175 is a better direct fit for most applications. Personally I'd go with a BG Road Demon.
Re: Holley 4175 or 4011? (Smokehouse69)
I have the 4175. The vacuum secondary module did not allow the stock air cleaner to sit down without making a spacer. The taped hole in the base is smaller than the Q-jet so I had to use an adaptor for the power brake vacuum line. The throttle linkage and fuel line hooked up easily. I changed the discharge nozzle( from the .040 to.025), activator cam (Bought the cam package), and the secondary spring (small white). Going on 3years without any problems.
I have a 4010 (square bore cousin to the 4011) and there's a reason that Holley doesn't make them anymore.
Not an impressive carb by any means.
Why not look at a 4150 or 4160?
Re: Holley 4175 or 4011? (ddecart)
[Modified by AlwaysWave, 4:27 PM 9/16/2003]
Gotcha. I'd probably not go with the 4011 then. Might work for you, but I've yet to get mine to run well.
FYI http://c3vr.com/vrforums/message_go.asp?MID=21703
http://www.holley.com/HiOctn/ProdLin...f0-80555S.html
[Modified by redwingvette, 9:29 PM 9/16/2003]
