Fel-Pro 1 piece pan gaskets
Has anyone had luck with these? I've installed 2 now and I can't get them to stop leaking on the rear corners of the pan. My brother is having the same problem on his 383 too.
Re: Fel-Pro 1 piece pan gaskets (Steve Straus)
I too have a leaking oil pan using this gasket. My oil pan is old, so it could be warped. Also, timing cover is old and gasket could be getting failing. I can't say for sure the gasket is the cause.
Re: Fel-Pro 1 piece pan gaskets (Frankenvette)
I've used them in the past for my small block with great success. Now they are available for big blocks too. Installed mine less than a month ago, works awsome.
Make sure your pan rails are straight and don't overtighten. Uh, don't undertighten either
I just installed the FEL-PRO for a '75-350 (have not run the car yet, having electrical problems) but my instructions said to use a dab of RTV on the 4 corners. I did make sure my rails were straight tho. Others have said that no RTV was need at the corners. Maybe FEL-PRO is now suggesting RTV because of know problems?
BTW: with the metal insert in the gasket for each hole, I can see where it would leak if the rails were not completely straight and flat. I believe the GM torque is 8 lb/ft (rails) and 16 lb/ft (corners).
[Modified by KenSny, 5:21 PM 9/15/2003]
[Modified by KenSny, 5:41 PM 9/15/2003]
I've used it twice and have had NO leaks. You need to use the RTV in the corners as others have said.
Re: Fel-Pro 1 piece pan gaskets (Duke94)
Installed mine on my '79 L82. No problems
and my oil pan is not the straightest either
Put one on my car this spring. No leaks. I beat my oil pan flange so it would sit flat, but that was a minor issue.
I planned on trying one of these, but I want to do it the next time I pull the engine out. I also want to pressure test the block for oil leaks BEFORE I put her back in the car-- if I can figure out a good way to do it, that is.
Re: Fel-Pro 1 piece pan gaskets ('75 383 ElkGrove)
or maybe you could do it at home without cranking. connect a small pressure vessel filled with oil to the dry-sump inlet port. pressurize with compressed air at while turning the crank by hand. there would be some backflow through the oil pump but it still should pressurize. ??
[Modified by Turbo-Jet, 6:18 PM 9/16/2003]
Re: Fel-Pro 1 piece pan gaskets (Turbo-Jet)
I was thinking of putting the assembled engine on a stand, then somehow adapting my air compressor to the valve cover hole, and just putting some pressure in to see where it leaks out. That way, I can install her into the car with NO oil leaks, right from the get-go, versus trying to track them down once the motor has been installed.
Sorry for the late response. I've been without phone and power for a little bit.
On the first install I used just the dry gasket and dabs of blue RTV on the corners with the second one. The pan is a brand new milodon pan.
I think I'll switch back to the cork gaskets and see if I have any better luck.
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: Fel-Pro 1 piece pan gaskets (79MakoL82)
:iagree:
:iagree:
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Just to get this straight, you guys are all suggesting "just a dab of RTV at the corners" and no other RTV on the gasket?
Re: Fel-Pro 1 piece pan gaskets (Captain Morgan)
That is what is on the directions.
