If you are looking for your build sheet (1979) I may have it
I found a build sheet under the rear wheelwell insulation of my car.
If you have a Brown 1979 4speed with Doeskin Interior VIN 1Z8749S432292 then I have your build sheet.
If you want it, I can send it to you. I don't know why it was in my car...
PS. I did check the 1979 registry, it's not listed.
Re: If you are looking for your build sheet (1979) I may have it (Northwest79)
Hey Chris:
I've got a 78 with the window sticker but no build sheet and trying to figure some things out. If no one claims it I would like to have it or a copy of it...let me know.
Re: If you are looking for your build sheet (4rensic22)
It's my understanding that the build sheets are normally on top of the gas tank in our cars.
I would like to see the owner of the car get the build sheet if possible, so I will probably hang onto it... but if I can help you figure out whatever it is ..
let me know !
let me know !
If you're not an NCRS member, consider finding a buddy that is to post an entry in the Driveline - it's free to members.
Re: If you are looking for your build sheet (mayberg)
I found mine under the passenger side carpet. And I suppose there's a tank sticker also. I've heard they are found in different spots on the 79. The workers must toss one in as they are finishing up.
Re: If you are looking for your build sheet (Shark79)
The build sheet matched the rolling chassis to the body with the proper VIN. That is why some people find two sheets: one glued to the top of the gas tank and one underneath the dash, normally on the passenger side.
