Moved to Maine, and got a radiator leak ?
got a radiator leak from the core side leak starts after the car runs or travels then the car sits for about 15 minutes, then leaks about 3 0r 4 ounces of fluid
should I change the radiator?
Also anyone from the forum in Midcoast maine
Re: Moved to Maine, and got a radiator leak ? (TFranchini)
i dont have answers but i wanted to say hi cause i was born and raised in westbrook, maine (near portland) i live in florida now...
hope you like snow and cold! :jester
"got a radiator leak from the core side leak starts after the car runs or travels then the car sits for about 15 minutes, then leaks about 3 0r 4 ounces of fluid
should I change the radiator?"
Depends where the leak is! Might just be a hose.
"Also anyone from the forum in Midcoast maine"
Southern Coast here.
As far as snow goes - on average, you are right, you will get less on the coast. For getting snow there is no substitute for higher elevations. On the other hand, if the conditions are right and a Nor'easter forms up...well...you'll see.
