competition vs super comps??
Re: competition vs super comps?? (LT1driver)
I can`t tell you the difference but I have Hooker competition/ race headers w/side pipes and there is NO way to install a muffler the side pipe is bent at both ends. ...redvetracr
Re: competition vs super comps?? (redvetracr)
I think the Comps are 1 5/8 tubes and not very equal length. The Super Comps are 1 3/4 tubes and the length is more equal. This is for small blocks not sure on big blocks. I am running the Comps on mine and they work fine
Re: competition vs super comps?? (Gordonm)
Comp approx $140
Super approx $300
Why? Super comp are lighter, and they somehow 'make more power'.
http://www.holley.com/HiOctn/TechSer.../ESHHTech.html
Super approx $300
Re: competition vs super comps?? (Boofers)
Super comps are larger tube, equal length headers, and thus make more upper end power but sacrifice low end torque. You need an engine that lives in the 3-7K range or higher to benefit from the Super comps. Having said that, it was the single best thing I ever did for my BOSS 302. Absolutely amazing increase in performance.
Hans
Hans
Supercomps also have a thicker flange along with equal tube length.
Only straight plug heads with the SuperComps.
Work great even on the 327's
Re: competition vs super comps?? (mountainmotor)
I went with Sanderson headers for my BB, there quality and fit are excellent and I paid less than what the super comps cost. Mine are block hugger design with 1 3/4 tubes into a 3" collector. I have heard that Hooker has had many quality problems and so far after 2+ years mine are still perfect. Check them out on the web at http://www.sandersonheaders.com . I think a few other members have them as well, very good product you will like them. Oh yeh, get the jet coated ones......
Re: competition vs super comps?? (467-Ratman)
I have angled plug heads too, Trick Flow 23 degree installed with no problems on my 388ci motor. I have the Super Comp. Sidepipe headers and I used Stage 8 header bolts to lock them down.
Neil in Tenn
[Modified by Nomad78SA, 5:14 PM 9/13/2003]
Neil in Tenn
