Tranny cooler
Tranny cooler
Have any of you guys installed a tranny cooler? And if so, where? I have a 76 and I am thinking on the front of the a/c condenser. Also I saw a cylinder shaped aluminum transmission cooler that looked like it would be easier to mount, but I dont know how effective it is compared to the regular tranny coolers.
-Karl
-Karl
Re: Tranny cooler (ill_driver)
With the simple hinge pin arrangement they did at GM, I don't see any extra room for a 'normal' ATF cooler, I had to put mine behind the a/c condensor, in beteween....
GENE
GENE
Re: Tranny cooler (Alwyn678)
Mine is mounted to the center bumper support. Its mounted in a downward angle so it can pick up the air that flows in from underneath.
CI 6-7-8 Veteran
CI-VIII Burnout Champ
St. Jude Donor '06-'10, '13
Re: Tranny cooler (Jvette73)
I was eyeballing between the front crossmember and the lower radiator support.
Re: Tranny cooler (BSeery)
I mounted mine between the rad and the AC condensor. I didnt move any of the parts either. The hands got a little cut up but its in.
Put all the hoses on the cooler first and then slide it between them and use the rad as your mounting surface being sure to use the little rubber pads to keep them separated. I pushed the plastic ties from the rad side up through the tranny cooler.
I used to be able to feel my shifter getting a little warm on the steel shaft, now it stays real cool. I used a 15 x 8 x 1/2 cooler.
Brent....
Brent....
Re: Tranny cooler (Red73)
I see problems with mounting any cooler out of the FAN generated airflow....it's just hanging in still air doing basically nothing when stuck in traffic.....on the freeway, down in front is fine....but around town, inadequate airflow.....
GENE
GENE
I removed the condensor 2 weeks into owning my vette. I left the mounting brackets, though.
In its place, I now have the B&M 24,000 gvw tranny cooler. I used the supplied erector set-like brackets to mount it to the remaining condenser brackets.
Be careful when you install the hoses. DOUBLE CLAMP is my advice.
I ran her for 20 minutes in my driveway checking for leaks-- none. Then I drove her 5 min. to the parts store to show my buddy my handywork.
I opened the hood, went inside, came out with someone to show off my car to, and then as we watched she caught FIRE :mad . Luckily I carry at least 2 extinguishers at all times, and the fire lasted only 15 seconds. PLUS, my engine was NOT running, so I guess that saved me from sucking in the super-fine powder into the motor. The line was leaking only under high pressure, it didn't blow off, or split, or anything. It just leaked when I drove her, or got on it.
Combine the tranny fluid with header wrap, and you've got yourself an under the hood zippo lighter!!
Back to the original subject:
CHP had an article recently that showed the best position for an oil and/or tranny cooler would be in front of the condenser. That way it has the benefit of the fan pulling fresh air through it. Mounting the cooler behind the radiator or condenser is a bad idea due to the cooler receiving heated air, but at least it still has the benefit of fanned air rather than mounting it out of the way where it'll get no airflow while sitting in traffic (I don't think there's any room to mount one between the condensor or behind the radiator on a C3 anyway).
