Shades of semi gloss black?
I also posted this in the Factory Correct restoration section, but th eC3 guys might be able to shed some light on the subject aswell.
I was at a local car show on Sunday and there was quite an impressive display of vettes.
I have been trying to get my car as "close" as is reasonably possible to factory correct and noticed the different shades of semi gloss black on one particular car that the NCRS judged to be damn near perfect.
How do you get different shades of semi gloss black? I spoke to the owner and he said he used Krylon paint (semi and gloss black)...so whats the trick?
I believe the A-arms are supposed to be a different shade than the chassis rails (as his where)...looked very nice i must admit.
Thanx
Nick
[Modified by lvrpool32, 3:45 PM 9/10/2003]
Thanx
Nick
Re: Shades of semi gloss black? (lvrpool32)
Yes, there were variations in the gloss levels of the frame, engine compartment, and suspension components. Krylon makes a semi-flat, satin, and semi-gloss that are all good for their respective areas. Also, John Deere "Blitz Back" is an excellent paint for many of the semi-flat areas under the hood. A-arms were typically glossier than the frame and other components. Get an NCRS judging guide for a full breakdown on all the different colors and gloss levels.
Shannon
Shannon
Re: Shades of semi gloss black? (sb69coupe)
Hi Shannon,
I have the NRCS manual and also the Vettue Vues 1968 to 72 book and they do state the difference in "finish"
I used te semi flat black on the inner fenders and chasis rails, the gloss was too much in my opinion for the A-arms....so i tried applying the gloss and before drying applied a light coat of semi-flat....seemed to work, issue now is repeating the effect on the lower A arm and on the other side.
Nick
Nick
What you are looking for can be obtained through using Krylon "satin black". or Plasti-Kote "T-3 hot rod black" and finally a lot of guys are having great sucess with John Deere "semi flat". Your choice, I use the Plasti-Kote available at any Kunkels auto parts store. Check it out, remember my car is and has been judged-----------no problem. :cheers:
Re: Shades of semi gloss black? (Indy Year 25)
Krylon "satin black" is closest, however that is just my MO. Let me ask the wizards, and I will reply. :cheers:
Re: Shades of semi gloss black? (GREGG-73)
You can use acrylic enamel (black, naturally) and mix flattening agent with it to get the desired shade your intrested in. You can purchase both at your local automotive paint store. :flag
Gregg, I really appreciate you checking this out for me!!!!!
GREGG, thanks once again. I think I will give that one a try. My car will never be NCRS (at least while I own it) I just want to be sure it looks good.
Anybody have experience with the SEM TRIM BLACK?
BTW, Beautiful car!!
